TwinTurbo.NET: Nissan 300ZX forum - Crimp the iacv hose it will stall motor. if not theres a
93 Blue Z32(NC)
on August 12, 2013 at 11:06 PM
Anyone ever had an issue of a PCV hose cracked causing
posted by inf
on August 12, 2013 at 07:03 PM
air leak around intake
inf
19:03:46 08/12/13
The Hoses never see Vacuum.
Cjw3
19:23:55 08/12/13
hmm...perhaps the hose is causing a venturi effect
inf
19:53:13 08/12/13
Crimp the iacv hose it will stall motor. if not theres a -
93 Blue Z32(NC)
23:06:32 08/12/13
after fixing the pcv hose I found some other leaks...
inf
13:05:04 08/13/13
nothing (n/m)
inf
13:21:02 08/13/13
it stalls (n/m)
inf
13:27:29 08/13/13
hmm, only one other leak as determined by a boost leak test
inf
13:35:32 08/13/13
ya for whatever reason I can't get this vehicle to idle
inf
15:50:40 08/13/13
hmm...i swapped the ecu with an auto trans tt federal
inf
16:16:43 08/13/13
weird..code 51...perhaps that's why the idle was funky..
inf
16:20:27 08/13/13
chalkin this one up as a loss...
inf
18:34:03 08/13/13
clamp off until u get idle down to 650 and ck timing (n/m)
93 Blue Z32(NC)
22:18:53 08/13/13
Re: air bypass hose from intake pipe also iv seen air
93 Blue Z32(NC)
22:26:08 08/13/13
ya, i've had a sentra that a coilpack was killing the ecu
inf
13:36:24 08/14/13
